Onkyo 606 question.
beater
72
When playing some blu-ray discs on my BD30, (i.e cars that has dolby digital ex and true hd) the onkyo displays dolby digital ex on the main display with true hd in the top left hand corner in red,and other discs (i.e national treasure 2) display true hd on the main display.Am i still getting true hd from cars.
paultcon
I can think of two things to check, 1st what way your amp is decoding the soundtrack. On the Onkyo amp it shoud be set to direct to decode the sound on the disc as is, the DDEX you see on the display could indicate that it's applying that format as its decodeing format. 2nd check the disc setting not every disc is going to have DD True Hd as the default setting so maybe one disc does and the other doesn't.
Hope that helps
beater
72
Thanks for your reply paultcon.I have checked all my amp settings and have set the disc to play True hd but the display still reads the same.
