How can I know if is solid core?Mr Morph said:. If they're solid core cables like Audioquests old 'Topaz' and 'Quartz',
Brilliant parody.rbrierle said:No! Cable technology has come on in leaps and bounds since 2004! Get a current ***** cable, avoid stranglimg your music. Get high highs and low lows. Get silver ideally as it sounds less coppery than copper.
That's a good point. I wonder if you have to run the cables in longer, since they're old. Hmm - might cogitate over the weekend. Or go down the pub, whichever is easier.ruivasco said:I´m trying the Coral Audioquest. So far, are great. :rockout:
As were new, it needed a few hours to burn in
altruistic.lemon said:That's a good point. I wonder if you have to run the cables in longer, since they're old. Hmm - might cogitate over the weekend. Or go down the pub, whichever is easier.ruivasco said:I´m trying the Coral Audioquest. So far, are great. :rockout:
As cable is a lump of copper 'running in' is irelevant. It will affect capacitors, speaker suspensions and some magnetic cores however. And cars, you need to run in car engines, although not in the way people usually run them in.altruistic.lemon said:That's a good point. I wonder if you have to run the cables in longer, since they're old. Hmm - might cogitate over the weekend. Or go down the pub, whichever is easier.ruivasco said:I´m trying the Coral Audioquest. So far, are great. :rockout:
To be fair, I think our citric friend was being whimsical and knows this cable running in lark is shall we say a tad dubiousGlobs said:As cable is a lump of copper 'running in' is irelevant. It will affect capacitors, speaker suspensions and some magnetic cores however. And cars, you need to run in car engines, although not in the way people usually run them in.altruistic.lemon said:That's a good point. I wonder if you have to run the cables in longer, since they're old. Hmm - might cogitate over the weekend. Or go down the pub, whichever is easier.ruivasco said:I´m trying the Coral Audioquest. So far, are great. :rockout:
No, only 5 years.Tromso said:I know its late to the party but Audioquest do have a cable archive section which gives details re construction
http://www.audioquest.com/archives/
