nads
886
238
19,270
[quote user="JohnDuncan"]Oh dear oh dear oh dear[/quote]
Nice, what did you upgrade from? What clinched it for you??
Thaiman
360
[quote user="JohnDuncan"]I bought a Primare CD player. Am I a bad person?[/quote]
result!
JoelSim
767
[quote user="Sam Srivastava"]Well done John (is my un-biased opinion)[/quote]
Totally unbiased Sam, lol!
John Duncan
2,033
27
19,720
Well it was 146 quid with 20 minutes to go. I couldn't not, really could I? Ended up £212........
And since the going rate for my 640c v2 is about 165/170 quid, that means I've, like, made 500 quid or something (this is the argument I used at home).
JoelSim
767
[quote user="JohnDuncan"]Well it was 146 quid with 20 minutes to go. I couldn't not, really could I? Ended up £212........
And since the going rate for my 640c v2 is about 165/170 quid, that means I've, like, made 500 quid or something (this is the argument I used at home).[/quote]
That's always a good argument, my brand new ProAcs were only £350 ;-)
Hi all of you, may I have a question. I
have a big Sony AV receiver and Jamo shelf speakers. The radio part of the receiver sounds ok if i turn the bass on to the full. But if I listen to my laptop mp3s the sound, although clear, lacks the bass! Should I add a subwoofer, would it solve the problem? I listened to some subwoofers at music stores, and found that they add
only a very little (although significant). I also found that
below 100-150 Hz I do not really hear anything. So what is your advice?
John Duncan
2,033
27
19,720
I had permission beforehand, unusually. It'll be just my luck for the cool green lights (sic) to be unacceptable aesthetically. And it is quite chunky........
Clare Newsome
1,657
And there's me thinking i'd grabbed eBay's bargain of the week by getting 5 mint Dusty Springfield LPs for £9.99
JoelSim
767
Unfortunately that's one of the problems with compressed music files like MP3 on an AV amp. You could try a DAC and higher resolution MP3 storage. I don't think a sub is the solution, but I could be wrong.
JoelSim
767
[quote user="Clare Newsome"]
[/quote]
5 Dusty CDs. Make sure you give them a good clean before you put them on your gramophone Clare.
John Duncan
2,033
27
19,720
[quote user="zenezene"]Hi all of you, may I have a question. I
below 100-150 Hz I do not really hear anything. So what is your advice?[/quote]
Hi zenezene - I would suggest you post this as a new thread in the mp3 forum, with an appropriate title like 'laptop sound'.
cheers
JD
