Not much bass to the B&W 603 S3 speakers!
Gel why do you keep swapping Amps .Just sit back and enjoy them ,if you cant you need a new Amp.
Because something always goes wrong and then I can’t fix, so I change it, but then when I go back to it works again! 🙂
I just changed back to my newer amp the LX805 and only this amp is plugged in now and with the new speakers and sub, it’s working perfectly.
If every now and then you want to run you system without a subwoofer.
Set your front speakers to Large in the AVR menu to allow full-range audio, and set the Subwoofer to Plus (or "Double Bass" or what ever pioneer refer to it as ) to have the subwoofer augment low frequencies even when front speakers are set to large. Then low/high pass the subwoofer to around the 50-40hz mark within the amps settings. also make sure night mode hasn’t been engaged, this will strip the system of any bass.
Or if you're still having problems and there second hand units or have been used in the the past with different equipment rerun the auto calibration as this will certainly affect bass performance and sound to a very very large degree.
Reactions: nopiano and Gel
Set your front speakers to Large in the AVR menu to allow full-range audio, and set the Subwoofer to Plus (or "Double Bass" or what ever pioneer refer to it as ) to have the subwoofer augment low frequencies even when front speakers are set to large. Then low/high pass the subwoofer to around the 50-40hz mark within the amps settings. also make sure night mode has been engaged, this will strip the system of any bass.
Thanks! 🙏
