Not much bass to the B&W 603 S3 speakers!
Gel
1,948
742
3,570
There doesn’t seem to be much bass to the B&W 603 S3 speakers, is this normal? My sub has currently stop working so no fix there.
Hi, from my experience with B&W speakers, they tend to be bass shy as a norm. Better placement and some way of biamp will help. One friend has old B&W 603 with pre/power from Musical Fidelity, 199X stuff, quite good sound. BR.
Reactions: Gel
Yep, that’s what AI was saying about the bass for these speakers too.
It's all relative!
Have you been using them with a sub? They are going to have less bass than you are used to.
The stats say they go down to 46hz. If I compare that to my Tannoy, they go to 39hz, that's probably because they are about 50% larger.
Firstly, make sure you are getting the most out of them. Have you recalibrated your receiver to tell it there is no longer a sub?
Have a play with the positioning, moving back towards the wall will reinforce the bass, but too close and it will get muddy.
Reactions: Gel and Shrek
Small to get the subwoofer working, which it currently isn’t. 🙂
That's weird Gel on my Denon I done the 7:1 calibration via software and the supplied mic, this was seamless process. It captured front and back speakers, the centre, SW and atmos.
Was it same with your Pioneer AVR? Perhaps you just need to recalibrate the whole thing again.
If all fails, reset your receiver to factory settings and start again.
It's all relative!
No I didn’t recalibrate the Pioneer, I will do that. Thanks
The Denon amps are excellent for calibrating, Pioneer amps not so. Basically I couldn’t get Bluetooth to work on it, so I unplugged the amp left it for 2 mins, and then replugged it, in this process the sub stopped working for some reason.
When you calibrate the Pioneer it works well, but then you have to select small speakers and sub. And 2.1 setup. I will try re-calibrating again, and see if that works. Thanks
I have just plug in my Pioneer VSX-LX70 amp and now the bass is better and I got my sub working on this amp!
Yes, this is what I am doing now, I have my Pioneer VSX-LX70 amp connected to the B&W 603 S3 speakers and the PV1 sub and listening to music Bluetooth wise from a Logitech Bluetooth device and is all going really well! I have even connected an optical cable for the TV sound.
The Pioneer LX70 can be a bit bright too but not with my 603s.
So I just connected my Pioneer VSA-LX805 up to my old speakers and sub and it’s working great again! 🙂 Perhaps unplugging it again did the trick.
