noobs querry much help needed
hey this is probably realy stupid but is there a way i could put my marantz pm5003 through a power amp to make it possible to drive bigger speakers ? if this is stpuid please feel fre to laugh / explain why .
FennerMachine
83
Not an expert on this amp but checked the specs & it looks like it has preamp outs so you can hook it up to a power amp.
Probably best to use the pm5003 as a pre-amp/control unit only with a power amp driving the speakers.
Not sure what power amp to go for but get a demo before spending!
You could then get a pre-amp later to replace the pm5003 for a further upgrade if you wanted.
Sizzers
188
This stirred my curiosity as I'd been thinking along similar lines a good while ago with my 6003 where I found I couldn't as it doesn't have pre-outs. Just checked the spec on Marantz's web site and nor does the 5003.
FennerMachine
83
Whoops! Sorry!
Your right, checked again, no pre outs.
The What Hi Fi specs say otherwise – I should have checked further.
Sizzers
188
No offence against WHF but I only check the manufacturer's specs.
I did check their review a while after posting and thought that's where you probably got them from! lol
ASK THE COMMUNITY
