[quote user="Scotsgirl"][quote user="stu31"]Hi,personally if its for freeview if at all possible i would as the professor suggests run another length of coax from the roof but without a wall plate straight into your tv/freeview box, my friend installs aerials for a living and tells me that you can sometimes loose a certain amount of signal by having breaks or joins even if its just a wall plate and as i found out it was the difference between a good picture and a very good picture[/quote]
Thanks for that.
I was looking at the video sender as thought this would be less expensive and less hassle.[/quote]
If you buy a video sender, make sure you can take it back if not entirely happy. Some of them can have appalling picture quality, I had a Philips one, sending the signal from my lounge to my bedroom, directly above. It was fine when I didn't move, but as soon as I moved it caused interference! Have heard that wireless network signals can affect the quality, but this could be false, I haven't tried a sender since being wireless networked.
