New Turntable/No volume!!
LenJ
I have just purchsed the LENCO L3807 turntable, beautiful bit of kit, however I am getting no volume on my albums, full up (max 50) equates to about 18/20 volume level that I played albums on my old deck .....Any advice/fix greatly appreciated.Details :
CD/Receiver Denon M39 DAB
QAcoustic 2020i Speakers
LenJ
The_Lhc
1,176
What was your previous turntable?
The Denon has no phono stage built in, and from what I can gather the Lenco doesn't have one either (although the manual suggests plugging straight into an amplifier L+R input, which is odd if it doesn't have a phono stage), that would give you exactly the problem you've now got.
LenJ
Thanks guys, I sussed out I need to purchase a phono pre amp, my previous deck was a cheap ION with a USB which I gather means the deck has a built in pre amp(The-Lhc. I you asked).Having never got into phono pre amps any recommendations
LenJ
LenJ
Depends on your budget but I would suggest the ProJect Phono Box MM might do the job always presuming you have a moving magnet type cartridge fitted to that Lenco....
Before you buy anything check out the recently released Schiit Audio Mani Phonostage if you can find a distributor. From all accounts it's extremely well equiped for what it costs. (...and although it's Schiit it is very good Schiit.... *biggrin* )
Lucas116
Hi, I'm new to turntables and have just got the following equipment:
Lenco L3807 turntable
SMSL SA50 amp
Wharfdale diamond 9.1 speakers
The sound level is very low with no depth, which is not what I expected having read/watched many reviews. I understood the turntable has a built in pre-amplifier, is this different to a phono pre amp, or do you think the problem lies with the amplifier receiver?
Any advice will be much appreciated.
thescarletpronster
10
Lucas116 said:
I understood the turntable has a built in pre-amplifier, is this different to a phono pre amp?
A phono input needs a separate pre-amp from the pre-amp needed by line-level inputs (CD and so on). The output from a turntable is far lower than that from CD players, and a phono pre-amp also has to apply the RIAA curve. If your amp doesn't have a dedicated 'phono' input, you'll need to buy a separate phono stage, I'm afraid.
