- Aug 10, 2019
- 2,556
- 5
- 0
I know this something of a "how long is a piece of string question" but in What Hifi they give some example set ups. A Budget System of CD, AMP and Speakers for £740 and a Midrange system for double that.
There is no way I could afford the high end system at £7695. If I am going to get great sound from the budget system I would like to spend that amount but if I am getting a serious improvement in quality I would consider the mid range type of system.
I will go and listen to some different set ups but before I go I would appreciate views on whether I am likely to hear a significant improvement for the higher price type of system i.e. mid-range compared to budget. Would I be able to really tell the difference blindfolded.
The music I listen to most is classical - lots of Baroque instrumental especially Bach.
To my mind there is no point is spending more money if the advantages are limited. On the otherhand whatever I buy is probably going to be with me for say 10 years and so there is no point in missing out on significant improved quality if that is what you get.
Any thoughts or pointers appreciated.
