New system advice
Ive just bought a pair of ex dem quad 21l speakers for 250 pounds {bargin), i have two systems in mind which are the arcam a70 amp and the cd192 or the cyrus 6vs2 amp with the cd6, ive used both makes over the years and im fans of both, i can get both boxes for about 1100 pounds, if anyone can give some advice that would be great!
Arcam and Cyrus are worlds apart. Arcam is warm and relaxed, cyrus will deliver more verve and punch. Depends on your music tastes.
thanks for the reply, i know there worlds apart its the speakers i dont know to much about as i snapped them up cheap without a demo, i know the traits of both brands well, its just a case of what would work well with the quads?
I'd be tempted to audition the CD192 and the 6vs amp....
jules.
Ive always put sound quality first so mixeing boxe's isnt a problem, ive had a cyrus 8 amp with a musical fidelity x-ray also arcam and marantz combos, a few others too. I will go for two matching boxes but the 6 and the 192 is a fine idea. thanks for your reply.
