jaxwired:lesmor: I have been researching panels for ages and will eventually add some , question is what difference did you find they made, marked or subtle?
Also the panels behind the speakers look low , I would have thought the centre of the penel should be lined with the centre of the speaker , am I missing something
The difference is somewhere between subtle and dramatic. It's definately worth doing. The number one most recommended application for acoustic treatments is called "first reflection point" which is usually the point midway between your chair and the speakers on the side walls, floor, and ceiling. If you only do one thing, it should be to absorb the midpoint side wall reflection. It's especially noticable when I crank up the volume.
Regarding the panels behind the speakers. I agree that ideally they should be hung slightly higher, but the framed art prevented that. Besides, the Dynaudios are rear ported and the port is closer to the bottom of the speaker, so the ports are actually firing near the center of the panels.
izpuuteejs: It would be great to see Your new Bryston gear!!
and I doubt it's only my opinion 😉
OK, I'll try and find time to do it. I'll try and post some updated pics very soon. I thought maybe people had enough of my pics. But since you asked...
Thanks for the quick response.
The ported speakers makes sense to me now as does your first reflection point explanation , thats where Ill be treating first , along with the rear wall.
Then probably bass traps
I'll be treating a Home Cinema so quite a bit to do
