- Aug 10, 2019
- 2,556
- 2
- 0
Hi guys
Could you please recommend me some speaker cable, I will need a total of 6 meters of biwire cable (cut into two 3m runs) I have a slightly bright sound at the moment and would like to take the edge of the treble. I know cables can't fix a bad sound and I really like the sound my kit produces, but I think I could do with calming the very edge of the treble.
I currently use QED silver anniversary (not the newer XT) biwire. I have been told this is a bright sounding cable. Could you please point me in the direction of some "less bright" cables. Happy to spend as little as possible up to about £10 - 12 per meter. Will consider spending a bit more if its really going to be worth.
thanks in advance.
Face.
thanks in advance.
Face.
