New Sony DA2400ES faulty? should I send it back?
roger06
374
Hi
Further to my post re: a really quiet centre channel on my Sony DA 2400ES, I have performed the following tests:
1. Set all 3 front speakers to the same level (0bd)
2. Using the test tone the centre is significantly quieter than the front L+R. (ie you can't hear the dialogue in a movie)
3. I have swapped the centre for a spare satalite speaker - same problem.
4. With test speaker I've changed the speaker cable - same problem.
5. Using original centre speaker I've changed the speaker cable - same problem.
6. I've swapped the centre speaker and left front - centre channel still really quiet.
I think I've done enough diagnostics to ascertain the amp is faulty and the output level on the centre channel is not as it should be. I think I should send it back to Amazon for a replacement - what do you think ?
roger06
374
Thanks Prof for that succinct but helpful reply!
I've now tried 3 different speakers in the centre and 3 different cables so have requested a replacement from Amazon who are very good and send you the replacement first, then you arrange a courier to pick up the origina...
You should send it back. A friend of mine purchased a faulty Sony that, thurned out to have been damaged in transit. He got a replacement which works perfectly.
roger06
374
Thanks guys. I've checked and double checked all the connections etc so it must be faulty.
Watched Pearl Harbor (yes I know...) last night (PCM on Blu Ray) and with centre on +10 and all else on -10bd could only just make out the dialogue. It doesn't sound too bad on Pro Logic with the TV - but using the test tone the difference in volume levels is obvious.
Gerrardasnails
295
roger06:
You will be very pleased when the replacement turns up. Amazon cannot be faulted in my opinion - they offer a fantastic level of service.
