new setup - advice please
[size=3 face="Times New Roman"]Hi there,[/size=3 face]
[size=3 face="Times New Roman"]I’m a complete newbie when it comes to hifi. At the moment I just have a Panasonic home stereo connected up to my laptop, it does the job but the subwoofer is gone so I’d like to upgrade. I solely listen to music off of my laptop.[/size=3 face]
[size=3 face="Times New Roman"]Here’s what I’m thinking of getting:[/size=3 face]
[size=3 face="Times New Roman"] [/size=3 face]
[size=3 face="Times New Roman"]Laptop[/size=3 face]
[size=3>[font="Times New Roman"] [/font][/size=3>[font]
[size=3>[font="Times New Roman"][/font][/size=3>[font][/b]
[size=3>[font="Times New Roman"] [/font][/size=3>[font][/b]
[size=3>[font="Times New Roman"]HRT Music Streamer II [/b](dac)[/font][/size=3>[font]
[size=3 face="Times New Roman"]QED Reference Audio J2P[/size=3 face][/b]
[size=3>[font="Times New Roman"]QED Silver Anniversary XT Biwire speaker wire (2.5m) [/b](to connect active speaker to passive)[/font][/size=3>[font]
[size=3>[font="Times New Roman"]QED profile stereo phono to phono (3m) [/b](out from active speaker into:[/font][/size=3>[font]
[size=3 face="Times New Roman"] [/size=3 face][/b]
[size=3 face="Times New Roman"]and 2 Clearer Audio Copper-Line Alpha (mains)[/b] to plug the speakers and subwoofer into, and a Lindy 6-way extension[/b] as I don’t have enough plug sockets in my room.[/size=3 face]
[size=3 face="Times New Roman"]I will make some custom speaker stands as i've heard the a5's sound better off of the desktop.[/size=3 face]
[size=3 face="Times New Roman"]Some people may say the subwoofer isn’t needed, but its an essential to me as I love bass-y music.[/size=3 face]
[size=3>[font="Times New Roman"]I would really like some experienced users opinions[/b] on this setup. Given that its going to cost nearly £1000 I want it to sound good.[/font][/size=3>[font]
[size=3 face="Times New Roman"]Is the anything in the setup that is unneeded?[/size=3 face]
[size=3 face="Times New Roman"]Is there any components in this setup that you would change?[/size=3 face]
[size=3 face="Times New Roman"]The setup is for my uni dorm room, my budget is sub £1000 for everything, I would realy appreciate your advice.[/size=3 face]
ok first .....
As an owner of the HRT I think that is an excellent purchase.
I would lose the Wireworld ultra ....just use a generic usb cable( save some money)
the QED bi wire I dont think is needed,,,just £5 m regular speaker cable
yes to the Lindy...
not really sure you need the copper audio.
everything else should give you a great Uni set up......
just save some money on the cables........and spend it on beer...
I would tend to agree.
I would use a generic usb cable. If you want some decent analog interconnects you don't need to go to overboard. Try the QED Performance 1 or the Chord Crimson Plus.
Spend as much on your components at possible at first then if you want to try power cables etc later on then you can add them when you have the spare cash.
Or, you could try to find a second hand pair of Dynaudio Focus 110. You wouldn't need a sub with these. As much as you love bass without having a large space you won't get much if any benefit from a sub alongside the Dyn's.
thanks for the feedback guys.
In terms of speaker wire, some of the QED wires are cheap, but come unterminated. How important is the termination? Is it better to have a decent wire that is terminated or a good wire unterminated? I think the a5's have banana plug inputs, so I dont know if unterminated wire can connect to them.
