New House - daft question
Hi
I've recently moved into a new house and had sky out to set up my HD box. As with new houses nowdays, you have to buy an aerial seperately and as I watch everything via sky, I don't really see the point.
However my wife is looking for a small screen for the bedroom and I dont want to pay an extra £10 per month to sky for multiroom
If I buy a tv with freeview, do I have to arrange to have an aditional satelite dish or indeed by a aerial for the house to be installed.
I guess I won't be able to pick up the channels from my sky dish?
Thanks folks
Andrew Everard
1,878
No you won't. You could buy a set with Freesat and run it off a quad LNB on the dish, but these tend to be larger and more expensive sets at the mo.
Freeview requires a conventional terrestrial aerial. Having one fitted will cost you £100-150 or so.
Alsone
68
Or you could buy an ordinary flat panel tv in the sales and add a Freesat box to it to get Freesat.
Freesat boxes range from around £40 for the cheapest SD to around £100 for the cheapest HD to £299 for the Freesat +. You would still need a quad LNB though. An SD box and quad LNB will work out around the same as a Freeview aerial with the cable added in. A HD box will cost more than a Freeview aerial but give you the advantage of the limited HD service.
why dont you run a coax cable from the RF out on the back of the sky box to the bedroom and buy a magic eye so you can control the sky box from the bedroom quick and cheap
bretty
248
If you have a good freeview signal where you live, an indoor aerial is sufficient. I get full signal on my bedroom tele with one of those old style 'hoop' aerials you get with portable tv's.
VoodooDoctor
81
69stretch01:why dont you run a coax cable from the RF out on the back of the sky box to the bedroom and buy a magic eye so you can control the sky box from the bedroom quick and cheap
This is what I do and unless you want to watch different Sky channels at the same time it is a very neat solution. I had the aerial man install a double socket in the lounge and a splitter in the loft so that I didn't have to have cable laid out from the living room to the bedroom.
JamesOK
86
I've also recently bought a new house with no aerial (its amazing what they think are extras!). The builder will put all the cabling in so if you have a TV socket in the bedroom you'll find the corresponding cable lying about in the attic. Then its just a case of getting an aerial from argos, sticking it in the loft and connecting the cable to it. Much cheaper option than getting an engineer to sort it out and pretty simple too!
