nemark tt1650 deck
Freddy58
151
148
18,770
Freddy58 said:
MikeRed said:
Cambridge Audio A5 amp has phonn also Denon pma 250se with phono does not work with either
Sounds like a faulty deck then.
Just to add, I can only imagine it's the wiring that carries the signal, so I guess it's that that's causing the problem. Thinking about it, it might also be the cartridge. Check for loose/removed connections.
