Hi
I'm soon planning on buying a DacMagic and a Yamaha Subwoofer to go with my MacBook Pro and Lars & Ivan BK-21 kit.
The advice I need is what type and make of cables I need to connect it all together:
1. An optical cable from the Macbook Pro into the DacMagic - but recommendation on which make of cable to buy?
2. A two RCA to 3.5mm cable to connect the DacMagic into the Lars & Ivan amp - again which make of cable am I looking for?
3. What make of 3.5mm - 3.5mm subwoofer cable do I need in order to get a decent one?
(Okay, I'm sure someone will want to criticise my planned set up so go ahead! The system is only for a smallish study however and at the moment I'm not worried about streaming anything to other rooms. The MacBook Pro just purchased has been upgraded to 500Gb hard drive and all my CDs have been re-loaded in lossless format. The DacMagic seems like a good buy anyway for PC based music, the Lars & Ivan speakers get a big thumbs up from my girlfriend and for anything AV that's saying something so is a big plus, the Yamaha sub-woofer is needed with the set up as the L&I speakers are very good but need a bit more bass and this sub can also be paired with my PSP-600 soundbar for when I want to watch a good film. I don't have room for putting the speakers on stands either so anything more hi-fi is limited)
