Need help identifying this amplifier
jimman2
This was used with a Dynaco PAS3 pre-amp and a Fisher KM60 tuner (tube).
http://i955.photobucket.com/albums/ae32/jimman2/amp1.jpg
http://i955.photobucket.com/albums/ae32/jimman2/amp2.jpg
http://i955.photobucket.com/albums/ae32/jimman2/amp3.jpg
floyd droid
39
Certainly been tarted up. Looks also like the transformer has been removed from its original location ,note the fixing brackets.
Hmm , needle haystack.
jimman2
I'm in US - this was installed in a custom adapted TV console cabinet hidden from view - it never had it's own enclosure.
Thanks -Jim
floyd droid
39
Ah I was on the right track then. If it was in a custom adapted console then its either.
A. As Chebby said a Home made jobbie. Or B. Dismantled from something else.
Good luck in your quest jimman but I think its going to be a very long journey.
davedotco
Maybe something like a Hafler.
Right sort of vintage and often used in combination with Dynaco, available as a kit so you could by the componebts and build your own case work.
Those were the days........ :dance:
