Need HELP choosing TV
AhriGG
Hi im currently trying to buy a new tv and have narrowed down my choices to 4 TVs;
PHILIPS Ambilight 65PUS6814
Panasonic TX-58GX800B (2019)
SAMSUNG UE65RU7470UXXU
Hisense H65U8BUK
Not sure which one to go for., im open to suggestions( Budget just aound £750 and its main use is movies/tv shows with some gaming).
gel
Moderator
Hisense H65U8BUK
I would go for the Philips TV.
AhriGG
I personally like Philips TVs but perhaps the Panasonic is better for you:
The WHF review seems to tick all of your boxes.
I just found the Philips PUS7304 58” for 630 might go for that one, since it offers everything Panasonic does but cheaper
gel
Moderator
Have you seen this deal:
5 year warranty included and you get 90 days free returns from your home:
I will quickly look at the spec...
gel
Moderator
I am not sure if you get Netflix and Amazon Prime though, try and get a good return policy on the Philips just in case.
gel
Moderator
I found YouTube on my Philips 55pus6703 to be great I couldn’t see what all the fuss was about with online content. And it never switched itself off or anything like that or lost connection.
AhriGG
Ended up buying it, haven’t found any better deals since, only issue is that it doesn’t have Freeview but I have virgin tv box so it’s not a problem. Ty
ASK THE COMMUNITY
