Need a new hi-fi kit rack
Cass
Atacama Equinox seems to be the one to go for based on reviews, and not a bad price. Anyone got one? If so, what do you think?
I've not got one but I noticed that it is very deep, so if space is an issue maybe not the best.
I've just bought a Custom Design Milan, the proportions of this are much better suited to what I need.
If you have the room you can't go wrong
take a look at the partington minim, just ordered one myself
I have the Atacama Equinox AV and am very pleased with it. It is sturdily built and good-looking. Atacama are a good company to deal with should you need spares at any point (there are little rubber discs that you stick between the glass and the metal frame, which I have had to replace).
Recommended.
VoodooDoctor:I have the Atacama Equinox AV and am very pleased with it. It is sturdily built and good-looking. Atacama are a good company to deal with should you need spares at any point (there are little rubber discs that you stick between the glass and the metal frame, which I have had to replace). Recommended.
Where can you get the spares from? I could do with some more of the sticky discs with ball bearings.
thanks
do you have a link? Atacama.com is some minerals company and the .co.uk one doesn't look relevant either.
EDIT: ignore me found it
EDIT 2: wow £20 for 4 sticky pads and 4 ball bearings.
Something a little elegant/minimilist?...
http://www.quadraspire.co.uk/product_range/q4/page1/index.html#
One day I will will cough up the required £255 for a 3 shelf one in Maple to match my desk, bookshelves and speakers
I got the sticky pads for free. Guess loads of people are losing those cups and bearings...
I also have the Equinox Pro stand for my hi-fi. Happily recommend that too.
The Custom Design Milan is the best looking rack on the market at the moment, and if I were in the market for a rack...
ÿ
