Naim or Roksan or....?
maccalennon
7
Hi
Im in the process of trying to choose a new stereo Amp to pair up with my Sonos system and Monitor Audio Gold speakers.
Because music is played mainly from the sonos i am going to pass it through an Acram DAC.
the amp must have preouts to attach to my Av amp. Budget is about £1500.
I have heard the Naim NAit XS and it sounds good but occasionally a bit muddy where heavy bass is concerned but that may have been caused by the speakers that I heard it through.
Im also considering the Roksan Caspian M2.
Any opinions on which youd go for with my speakers would be appreciated (other alternatives also gratefully considered)
cheers
Shanka
123
I can not say which would go with your speakers especially as I am in process of looking to replace mine at present but I was in the same position with the Naim and Roksan and found the Caspian blew me away.I thought it was more detailed much punchier although still very musical unlike say the cyrus .
I am still very happy with mine and just looking now for the perfect speaker out of interest I am trying to audtion some gs20's and will update on here once I have.
As all will say you should try and audition both together as it is a large purchase but I found this is not an easy task, impossible in London !!
Good Luck
maccalennon said:
Hi
cheers
The Gold series is traditionally good with Roksan and Arcam FMJ range. Heard them when I auditioned my Leema and sounded fine but there was no X-Factor.
Lost Angeles
130
maccalennon said:
Hi
Should you not be using the pre-outs from your AV amp to feed your stereo amp.? Your idea appears to defeat the idea of having a stereo amp or am I missing something?
CnoEvil
556
14
Lost Angeles said:
maccalennon said:
Hi
Agreed.
Preouts on the amp are for connection to active sub or power amp. HT by-pass would be a more useful feature.
