Naim Muso at John Lewis £630!
  • Start date
Deleted member 2457
chebby said:
Native_bon said:
why so low, or are they not selling them? *nea*
It was a one-off customer return (open box?) from John Lewis that gel just happened to be there when gel was in the shop.
It's in his other Nintronics related thread (I think).
Yep, it was fate! *biggrin*. John Lewis do big discounts on returned stuff.
chebby
1,251
24
19,195
It was a one-off customer return (open box?) from John Lewis that just happened to be there when gel was in the shop.
Deleted member 2457
buzz_lightclick said:
gel said:
Sorry it's sold to me. *biggrin*
Any good? Where's your review?
I predict it will be returned or sold on before Xmas *biggrin*
Yep, it's really good. The sound goes very loud and very clear. I can't use it with my iPad though and use it at the same time, which is a bit of a bummer. So just using it with my iPhone or iPod Touch. The sound is separated nice and clear. At first I thought it was damaged because the grill on the front of it is bent when up close but that's just the way it is. It can be used as a speaker for the TV too.
Deleted member 2457
spiny norman said:
jjbomber said:
So that could be anytime between 9 and 5 on at least 3 days a week!!!
Has he gone part-time, then?
*biggrin* I do like their ex-display and returned deals.
chebby
1,251
24
19,195
Can you unpick that sentence for me please?
In what way can't you use the iPad? With AirPlay? Bluetooth? Wired (with charging cable)?
What do you mean "use it at the same time"? Are you trying to play from more than one iDevice at the same time?
Deleted member 2457
When listening to music on the iPad via Bluetooth on the Muso, I can't use the wireless internet on the iPad at the same time. It keeps freezing.
chebby
1,251
24
19,195
Ok I don't know what will help then (assuming all your iPad settings are correct). I am listening from my iPhone using Bluetooth and typing this.
Maybe you can give Naim tech support a call on Monday.
You've had these issues before IIRC.
Have you connected the mu-so to your wireless router with an ethernet cable yet? It gives another level of stability.
Give AirPlay a go as well.
Deleted member 2457
No I haven't done any of that stuff. I can listen to music on my iPad and search the Internet though. But when I put the Muso in the equation that's when things get complicated.
chebby
1,251
24
19,195
I know someone joked about it but, seriously, do you intend to read the instructions?
Deleted member 2457
I read the quick setup guide. *biggrin*. I am just enjoying listening to it at the moment. But yes I will read them but I don't know when. I have just put them back in the box, so I will get them out again today, perhaps I will have a butchers then. There don't seem to be any big manual though, just little guides.
