ChrisIRL said:
I don't know what model the DAC chip in the NAD D3020 is but as DACs go it's not a very good one I've found personally. It's ok but a bit dull and flat sounding overall, needs volume a bit higher than normal to bring out detail. Also when connecting digital devices to the amp which will be processed by the NAD's built in DAC there is definately a noticeable drop in volume output versus connecting equipment to the amps analogue input.
I have connected an Arcam irDac to the amp via analogue and more recently an Arcam rBlink. Sound is fantastic using either of these and there is an approx 10db sound boost. Well worth getting an rblink and connecting via analogue. It's bluetooth betters that of the NAD's in terms of reliability of connection and the DAC is really good, not a million miles away from the irdac to be honest.
You can actually connect the rblink to the NAD via analogue and coaxial simultaneously and then flick between the inputs on the amp to do a sound comparision. The rblink DAC improvements become very apparent then.
Hi, I can quote this post 100 per 100. I also own and I used to be pretty satisfy about the NAD D 3020 and his DAC. Then, for portable reasons (get hi-fi from my laptop and iPad) I bought a AudioQuest DragonFly 1.2 USB DAC. FANTASTIC little device, it has a ESS Sabre chip, many said it is the best DAC chip in the businness, and yes I can confirm it is very, very good myself.
Just for test purposes, I connected the DragonFly to one of the analog inputs of my NAD D 3020 via one of my USB ports on my desktop system, and, what a big surprise, this sound a lot strong, detailed and better compared to the internal NAD DAC chip.
Don't get me wrong: the NAD chip is ok, then the sound with the DragonFly is simply to another level, like 10db stronger, more detailed, more open.
It sound exactly (it means very good) like analog inputs of my NAD sounds when connected to CD with a good transport and DAC, or like when I listen my 10,000 pieces record collection using my Pro-Ject Debut Carbon via Pro-Ject Box phono preamp.
I can hear the difference in sound between the DragonFly and the NAD DAC clearly and, yes, now I do use the DragonFly all the time on my desktop system too, and my listening pleasure is a lot improved. Sadly cables from my desktop are now growing too, so I will really prefer to stick with integrated NAD DAC.
Example: buy the new high definition Led Zeppelin I II III from HDtracks.com and play them via integrated DAC and via DragonFly 1.2 DAC: there is no comparison, it is another level of quality, the output you can listen from the DragonFly is emoionally incomparable to the honest listen offered by NAD DAC.
So I hope too, NAD will rething the DAC chip for them next D 3020 revision or so.
