Hi all, my NAD cd player will not play any discs at all - on the display it says 'no disc' any tips on a fix?
Thanks in advance peeps
Blackdawn said:As its not under warranty I would open it up and try to clean the lens. Maybe take it to a mate who knows electronics. There are some decent budget players out there that don't cost a fortune. Unless you can do it cheaply it would be worthwhile going for a new one.
knaithrover said:Hi all, my NAD cd player will not play any discs at all - on the display it says 'no disc' any tips on a fix? Thanks in advance peeps
davedotco said:knaithrover said:Hi all, my NAD cd player will not play any discs at all - on the display it says 'no disc' any tips on a fix? Thanks in advance peeps
To be honest it sounds like it needs a new cd 'mech'. In theory this should not be all that difficult or expensive to fix but these days 'mechs' can be hard to come by and a lot of service centres charge serious money.
The new Nad player costs £249 in the UK, you could easily spend half, or more than that on a repair perhaps not a good idea.
If you are happy to have another brand, Richer Sound have a choice of models around £150.
knaithrover said:davedotco said:knaithrover said:Hi all, my NAD cd player will not play any discs at all - on the display it says 'no disc' any tips on a fix? Thanks in advance peeps
So in your opinion it's not the lens?
Deffo wouldnt be interested in spending much on a repair as the player only cost me £60.....
Must admit i do like to go second hand to get more bang for my buck but maybe not such a great idea with cd players
eggontoast said:knaithrover said:Hi all, my NAD cd player will not play any discs at all - on the display it says 'no disc' any tips on a fix? Thanks in advance peeps
More than likely just a failed laser, your CD player uses one of the most common laser's. Just buy one of eBay, item number 251380468072, it will take you about 20 mins to fit and away you go for £4.20 (If you want to make life slightly easier you can buy the laser with motors etc for £10ish).
eggontoast said:If your gonna buy a complete mech with motors etc, you will need to get the part number off the original one. It will be something like KSM213CCM or CDM etc if you replace just the laser it will be the one I linked too.
