NAD C356BEE DAC. A decent upgrade?
dellroy
15
Finally decided that I am going to upgrade to single amp/dac to play my streaming a digitally stored music. Wife doesn't like the extra wires of a seperate dac amp, and has even decided to split the cost of the upgrade with me. So I want to set out and demo a couple of amps. Budget is £600.
I can get hold of an ex display Nad 356bee DAC for £500, which seems like a great buy. Would this be a big upgrade from my current amp (see signature). I have read some great customer reviews on this. An alternative would be Rotel RA 12 or Quad Vena. Both a bit more expensive.
Just after advice as I need to focus my attention on a demo as I will have to travel some distance and to different places to test the,.
I think that it will be a significant upgrade from the Denon, but I would always suggest that you listen to it first (ideally with the rest of your system) before buying.
NAD amplifiers are known to have a 'weighty' sound (especially in the bass) and so the type of music that you listen to may assist in whether the C356BEE is right for you.
Alternatively I would try the Quad Vena, or the Rega Brio-R (with a seperate DAC of course).
Sadly your budget isn't quite enough to get you anything really interesting. The Quad looks good on paper but I have yet to see one, let alone hear one.
A little more money will get you an Creek50a with Ruby dac module or maybe a Peachtree Nova. Very competent amplifiers in their different ways and very much the sort of thing that I (as a known contrary b*stard) would by.
If I thought I would be streaming a lot of Spotify, I might even take a look at the Nad D7050.
Thanks for the replies. Are NAD amps usually a good match for the Zensor 3 speakers? Would the Bassy sound of the NAD be too much for them?
I also think the NAD would be a great choice for your Zensor3,a very entertaining combo.Tone controls would help if you find something is not right.
