NAD c272 / 1155 replacement ?
Status
Not open for further replies.
Mercurys_cat
Hi all . I've used everybody else's topics for a long time so thought it about time I joined.
Basically I have a Nad c272 (150w) power amp from 2008 and a elderly (1984?!) Nad pre amp . The pre is falling apart but still performs ok. I recently bought some kef r500 speakers. Everybody told me to try the Nad c162 with the c272. I did and to my ears it was cold and despite being detailed the bass had evaporated .
My question is what do I replace my pre or both amps with? Budget £1200ish. I like a warmer , perhaps bass heavy sound. My gear = Audiolab 8200cd , rebuilt Rega p3 (inspire re build) with gold ring 1042.
Andrewjvt
99
Basically I have a Nad c272 (150w) power amp from 2008 and a elderly (1984?!) Nad pre amp . The pre is falling apart but still performs ok. I recently bought some kef r500 speakers. Everybody told me to try the Nad c162 with the c272. I did and to my ears it was cold and despite being detailed the bass had evaporated .?
And the c160 id of thought bass would not be an issue. The amp is a power house.
Are the speakers new? Did you demo them before buying. Bass on the r series is controlled and maybe you were used to a more flabby bass?
Mercurys_cat
hi and thanks for the reply. The kef r500 bass is deep and controlled with the 272 power and my ancient 1155pre. It was when I changed to the newer c162 that all bass evaporated . As the 1155 is falling apart I was hoping for a replacement to both or just the pre. Cheers . Ian
ER1C
if you decide to replace both I'm interested by your C272.
I was to buy => this one <= but I was on holidays and my internet connection failed.
I can offer you £200 including shipping to France. It's my best price because I'm not a rich man.
Thanks for reading.
Eric
CnoEvil
556
14
I suggest the Arcam A29, which seems to fit your criteria. There is also the Rega Elex R, Musical Fidelity M3si, Peachtree Deco 65, Creek Evo 50A, or possibly Croft Integrated.
Mercurys_cat
Thanks for the suggestion . A dealer told me the only musical fidelity amp the r500 would work well with is the m6si which is a lovely amp I'm sure but a bit over my budget. Anybody know what the Marantz pm14 s1 is like?
And did he just happen to have the said M6si in stock? ................ I think the world needs to know. :)
Mercurys_cat
yes indeed he did!
Mercurys_cat said:
yes indeed he did!
What a nice honest dealer he is eh?
Mercurys_cat
I've seen one going for £1600 . Having listened to its little brother in Hereford yesterday im not sure I would like it. The s1000 sounded thin and boxy in the mids . I quite liked the Marantz pm14 special edition .that ticked a lot of boxes for me except the price!
wandlerdarwin
If you still haveNADC272 I would be interested in buying it
Status
