Just a bit of advice if possible. My NAD C315BEE amp seems to have developed a fault. When I turn it on there is a fairly loud buzzing coming from both speakers. It's the same on any input channel, and isn't linked to the volume adjustment (I turn the volume up or down and the buzzing stays the same.) I tried disconnecting all the inputs, and no change. I also tried plugging some headphones in to it to see if it was the speakers, but the same buzzing comes through the headphones as well. Strangely, the buzzing comes from the headphones even when the amp is in standby, whereas the speakers only emit the noise when the amp it actually on.
It's about 6 months out of the 2 year guarantee, so before embarking on a mission to get it fixed I was wondering if it's likely to be anything I've done, or if there is anything I can try to fix it?
Thanks.
Thanks.
