- Aug 10, 2019
- 2,556
- 4
- 0
Hi all
I am having problems with my NAD 326BEE amplifier. After a short time of being used it just switches to standby (power light goes from blue to red) for no apparent reason. It will start and work again if I switch it off and then back on, but it will always go to standby again after a short time of playing music.
I am not playing it particularly loud and I am not using the soft clipping setting.
My setup is the above amp, a NAD 315 CD player and Monitor Audio Bronze BX2 speakers with chord cables.
I have noticed that it gets very hot and I suspect that this is causing the protection circuitry to cut in but I have not been able to find a cause. I have checked all speaker connections and also tried with different cables. There is no shorting from stray wires. My speakers are 8 ohm, 100w which should be no problem for this amp.
Here is the bad news, I bought the amp privately when it was one month old, it is now 11 months old, but had very little use over that time.
I have asked for help using the NAD site and after going through the usual fault finding checks they advised me to contact Armour Home to send it for testing/repair. NAD advised me that it would not be done under warranty as I had not bought it from a NAD dealer and also because the initial warranty was not transferable !! Armour Home have quoted £85 plus parts plus VAT.
I was under the impression that all goods came with a one year manufacturers warranty, apparently not with NAD though.
So If anybody has any suggestions what might be the problem or how I could sort it out, I would be glad to hear from you.
Many thanks in advance
