My System
  • Thread starter Thread starter Deleted member 2457
  • Start date Start date
Deleted member 2457
Hi
Is it okay if you take it down now? could you email me back the picture and delete it from the system permantly please.
Many thanks
Gel.
The your system page, mine had just gone onto the second page now and has been up a while now so I think it's best to take it down now.
Is it okay if you delete it for me, and make sure you delete the picture permantly for me., or email back.
Gel
You should have an 'edit' option in the same line as you click reply on.
Just go to your post in question and edit it - that way you can delete the info and picture links.
Hi Messiah, thanks for the help.
I have tried a couple of times now and it seems to be still there, I will ask again Monday, it might not be possible on the weekend.
Thanks alot
Gel
You will find the rib option in section 7. You can select to rib there.
It does help to keep your system pics permanently posted to inspire others when they're setting up their home cinema system.
One of the ways to delete the pictures would be for you to delete them from picasa or flickr (wherever the original pictures are, from where you got the link).
Hi, I have tried to delete my system pictures and post but it won't delete, could you please take it off now and delete the picture permantly or email it back I am not sure how you do it.
Many thanks
Gel
Andrew Everard:Thread deleted as requested, and no picture to return as we never had it - you linked to it on Flickr.
Cheer's mate, I have just deleted the picture in Flickr by clicking on the delete button there I presume that's the way to get rid of it there as well.
Thanks alot.
