This may be of help to anyone with a Sony HX853 TV
My Sony 46HX853 2D Settings For General TV Viewing, Blu-ray & 3D Done After 1hr Warm Up Time[/b]
On the home button[/b]
Settings>System>settings[/b]
Scene select: Cinema
ECO settings[/b]
Power Saving: Off
Scene Select Sync: Off
Light Sensor: Off
Idle TV Standby: Off
PC Power Management: Off
Display>Picture[/b]
Target Inputs: Common
Picture mode: Cinema 1
Backlight: 2 or 3 (dependant on room lighting)
Contrast: 90
Brightness: 50
Colour: 50
Hue: 0
Colour Temperature: Warm 2
Sharpness: 50
Noise Reduction: off
MPEG Noise Reduction: off
Dot Noise Reduction: off
Reality Creation: Off
Video Area Detection: Off
Resolution: Min
Noise Filtering: Min
Smooth Gradation: Off
Motionflow: Clear or Clear Plus for General TV Viewing & OFF For Blu-ray[/b]
Film Mode: AUTO1 or OFF
Advanced Settings[/b]
Black Corrector: Off
Adv. Contrast Enhancer: Off
Gamma: -1
LED Dynamic Control: Low
Auto Light Limiter: Off
Clear White: Off
Live Colour: Off
White Balance: RGB Gain / Bias -5 0 -2 -1 0 0
Detail Enhancer: Off
Edge Enhancer: Off
Skin Naturaliser: Off
i/p Conversion Preference: Quality
3D Settings[/b]
All Settings stay the same except the following Change[/b]
Display>Picture[/b]
Contrast:[/b] 98
Motionflow: [/b]Off[/b]
Film Mode[/b]: Auto 2
White Balance[/b]: RGB Gain / Bias -2 -6 0 0 0 0
Display>3D Settings[/b]
3D Depth Adjustment: 0
3D Glasses Brightness: Low
I hasten to add that these settings relate to my tv, all panels are not created equal, but it may be a good point to start from when calibrating your HX853.
Regards ...
ECO settings[/b]
Power Saving: Off
Light Sensor: Off
Display>Picture[/b]
Contrast: 90
Brightness: 50
Colour: 50
Hue: 0
Sharpness: 50
Resolution: Min
Gamma: -1
Clear White: Off
Live Colour: Off
Edge Enhancer: Off
3D Settings[/b]
Display>Picture[/b]
Contrast:[/b] 98
Regards ...
