My Sky HD box is annoying
Crossie
58
I have just made some upgrades to my system - Tacima mains conditioner, new leads and a new AV stand. I am very satisfied with the modest improvements all round. I used to have my sky hd box mounted vertically now it has its own horizontal shelf but it is making an annoying hum (fan ?). Has anyone any suggestions? I can't go back to having on its end, even though it was much quieter then.
Two steps forward......one step backwards.....
Thanks.
i had the same issue - i tried foam pads etc and they helped a bit - but once you're aware of the noise it seems like all you can hear!!!
In the end i just got Sky to come out and replace the box
The engineer told me this is usually caused by the fan's mounting not being a perfect fit.
The fact that the hum wasnt there when the box was vertical would also suggest the fan 'rubbing' a bit when horizontal but not when vertical. (I found the same to be the case)
If your box is still under warranty, i'd get it replaced...
One thing to note - if you phone up Sky about this - they'll probably ask if the fan noise is louder than a laptop - make sure you say it is and that it's louder than your normal Tv viewing volume - if you dont they'll try you palm you off with the noise being normal fan noise...
