My Sky HD box has died - after just one week
Tonya
57
Oh dear!
I guess you have tried the obvious, removing the power cable, wait 20 seconds or so, and then re-inserting it, waiting a few minutes, then turning the box on?
Alternatively, you could force a new software download by again removing the power plug, pressing and holding the "backup" button on the top of the unit. While still holding the button down, carefully re-connect the power cable. After 10-15 seconds a black and white picture should appear informing you of a software download in progress. At this point you can release the backup button. Leasve the unit to finish the download, usually 10-15 mins, then try to turn on. If this doesn't work, seeing the installation is so new, call Sky to arrange a replacement. Most modern electronic equipment, if defect, will fail during the first few weeks of operation.
Hope this helps!
matengawhat
695
15
18,895
tried unplugging didn't work
contacted sky and they are sending someone out tomorrow
just trying the backup now and i have lots of lights on and says updating so intersting to see if that works
thanks
daveh75
727
137
19,070
Assuming you've tried the obvious as tonya says, Get Sky out to replace the box, stuck in stand-by is a very common fault with Sky boxes.
matengawhat
695
15
18,895
box has now restarted and seems to be working - is it worth cancelling the sky guy as just a blimp or do you think it could mean a fault in the box?
VoodooDoctor
81
Don't think you should cancel. I'd insist on a new box as this could be an intermittent fault for you that will drive you nuts!
matengawhat
695
15
18,895
thumbs up for sky/installers - they called me today and i said i had got the box up and working again and hadn't had any other problems with it - the installer said could be a fault in the box, better to be safe than sorry - he had bought me a new one and just swapped it no issues - didn't even have to ask - makes a change!
D.J.KRIME
160
matengawhat:thumbs up for sky/installers - they called me today and i said i had got the box up and working again and hadn't had any other problems with it - the installer said could be a fault in the box, better to be safe than sorry - he had bought me a new one and just swapped it no issues - didn't even have to ask - makes a change!
Is the new one ok though? I've got one coming Friday - yes, bank holiday............
daveh75
727
137
19,070
Graham_Thomas:matengawhat:thumbs up for sky/installers - they called me today and i said i had got the box up and working again and hadn't had any other problems with it - the installer said could be a fault in the box, better to be safe than sorry - he had bought me a new one and just swapped it no issues - didn't even have to ask - makes a change! I've got one coming Friday - yes, bank holiday............Bank holiday's dont exist for Sky installers!
daveh75:Cofnchtr:Hi, Wasn't daveh75 was it?? ;-)) Cheers, Cofnchtr.IT wasn't me LOL...Wasn't working
It could be you tomorrow!
