- Apr 16, 2009
- 33
- 0
- 0
Hi
I'm putting together a budget for an upgrade; logical step is to replace the amp with an M6i; aiming for more presence and emotion, rather than the rather dry presentation from my A3.5. It will also be interesting to try some alternatives like the Supernait. I'll also be replacing the tuner with a second hand MF A5 tuner, then sometime in the distant future a new DAC
Would I also need to consider upgrading the speakers to do justice to the M6i, (keen to try options like Proac d18, Wilson Benesh Square 2, Monitor Audio GX200 etc) or would the GS10s rise to the challenge?
I want deeper bass hence floor standers, but due to room layout speakers are in corners, approx 0.5 m from walls and I already have to be careful positioning the GS10s to manage their bass; If i keep the GS10s I could get a Monitor Audio RXW12 Sub centrally placed and avoid the corner issues, I assume i could If I get tune the sub to meld seamlesly with the GS10s.
So should i budget for new floorstanders, new sub, or spend the money on more CDs instead?
