:bounce: :bounce: :bounce: :dance: :dance: :cheer: :cheer: :bounce: :bounce: :bounce:
Good Man - though you will need a new name, otherwise as you will melt...pehaps Fireman!
IMO You have just got the best sounding amp under £10k (and you'll soon be able to tell me if I'm right). It would not be really fair of me to compare it with your amp, as I don't get on with the sound of Naim. Suffice to say, that you should hear the most dynamic, detailed, natural, emotional and exciting sound, with seismic bass, that you have ever heard from your system.
This is the best amp that I've heard to date (other than a £30k VTL one) that I've heard matched with Focal.....imo they match each others strengths perfectly. You should find every genre of music handled well, as this is far from a "one trick pony".
DO NOT WORRY about the power on tap, as matched with your speakers, it can go uncomfortably loud (enough to damage your hearing long term). I also think it's even possible, that it will seem more powerful than the Naim. The joy though, is it's ability to play at moderate levels, and still sound exciting and punchy.
I'm sure Mac, Alex, Roby and Neuphonix will bear out what I'm saying.
As for source, look to Linn DS. I wouldn't go with a Linn CDP (sorry PP), as the cheapest DS (Sneaky) outperforms most (if not all) of the range.
I really hope you will end up as another happy signed up member of the very exclusive "35 Club", and am looking forward to your impressions. I think, my friend, you are about to cross the Rubicon.
Cno
