Multi-channel interconnects for blu-ray to amp
scene
OK, so I've got my old amp with multi-channel analogue inputs (an Arcam AVR250) and my new blu-ray player (a Sony BDP-S760
) and I want to hook them up using the multi-channel analogue connection (phono/rca).
So far so good. Now some dumb-ish questions:
  • How many phono leads do I need - 3 pairs or 4? I thought it would be four, but some previous threads seem to go on about 3 pairs being needed
  • Do I need to use different cables for the centre channel and/or the sub channel?
Any recommendations as to cables?
daveh75
scene:
No, just use standard stereo i/c's.
What's your budget for cables? Remembering you're going to need 3 or 4 pairs!
scene
OK people, thanks for that - 7.1 sound = 4 cables all the same (it's late, and I'm being dumb and tired!
As for the budget, I suppose I'd prefer to keep it to £100ish...
scene
daveh75:
Though you could buy some multi-channel/surround sound i/c's!
I use these, from Blue Jeans Cables between my BDP and A/V processor, and are excellent vfm imho.
Thanks daveh!
Those look very interesting - I was getting worried about the nightmare scenario of sorting four red and four white plugs at each end of the cable! (Out with the Dyno methinks
)... I assume you went for the LC-1 without the "Techflex" option
@nads:
I did say I was being dumb and tired...
much better now!
Maybe WHF should review some multi-channel cables for those among us who need / want to use analogue inputs on our amps?
scene
cheyworth:
I think ebay is your best bet.
Something like....
4* cable talk or
4* Chord
I would go for the Chord, you may get 4 pairs for less than £110 if you make an offer.
Chris
Thanks for that - I'll definitely look at that option, I'd forgotten flea-bay - they block it here at my work...
Andrew Everard
1,878
scene:Maybe WHF should review some multi-channel cables
Could do, but usually multichannel cables are just four pairs of standard interconnects, so will perform just like standard stereo pairs.
