Hey all!
As a few of you already know, I recently bought a Rotel RCD-06 and a pair of B&W 685's. Initially, I wanted a Rotel RA-03 integrated amp to go with this set up but had no luck locating one.
However, I have been offered an ex-dem (hardly used) Roksan Kandy LIII integrated amp for £350. It comes with a full manufacturers warranty, so hopefully should last a long time. It costs a bit more than I wanted to spend, but has the higher wattage that the 685's require and does look VERY pretty so I am willing to pay the extra
My question is, as I listen to mainly goth, industrial and electronica, will the Roksan Kandy LIII amp work well with the B&W 685's and Rotel RCD-06?
Also, what speaker cable and interconnects would you recommend? I was thinking maybe the Silverscreen speaker cable with banana plugs and Chord Crimson interconnects. Are banana plugs worth buying or is there something else that I should buy?
Any advice, as always, is VERY much appreciated.
Take care,
Rachel
PS floyd droid- I hope I didn't get you into trouble with the mods. I noticed that the RA-03 thread had mod corrections all over it
Take care,
Rachel
