Monitor Audio RS6. would these be good speakers to be paired with an Onkyo TX-SR875 ?
Hi again!
Thank you for the people that replied to my previous question about what A/V reciever to check out.
Next question is thoughts and opinions on Monitor Audio RS6 speakers to be paired with this unit?
Initially I may just buy the main front speakers and then in a few months, buy the other speakers to make up the RS6 A/V set up.
Obviously it would be a good idea to go and listen to this set up, but what are your initial thoughts?
Thanks again for the advice!
My contribution will be of no help..but I have bought the RS6 front and centre speakers to go with the Onkyo 905. I didn't audition them and so I couldn't say. I just relied on the rating in WHF! Tut tut many would say
In another thread Andrew Everard said that these speakers 'were okay..' with this system but said that it really needed a serious pair of speakers (but I can't remember the name!) - I recall that they were over a thousand pounds....Andrew can you help!
Andrew Everard
1,878
Yes, the RS6s will be fine with the TX-SR875. The speakers I mentioned before were the PMC GB1s, but as MS says, they're the wrong side of £1000.
I have just bought the TX-SR875 and went for the RS8's. Felt they would be better for music.
Thanks guys.
Not sure if there is anything else I should look at that would be suitable for both music and down the road....movies.
What would be a suitable CD player to go with Onkyo TX-SR875 and Monitor Audio RS6 speaker package. I listen to a wide range of music.
I plan you get a blu ray / HD DVD player and I beleive that the ones availble in the market right now don't play CD's that well.
help please.....
Andrew,
can you please advice. I dont want to get a separate stereo amp and was thinking of using the TX-SR875 with a decent CD player.
VoodooDoctor
81
I'm using a Rega Apollo with my Onkyo 905. Sounds very good. I do plan to get a separate stereo amp in the near future.
