FrankHarveyHiFi said:Well, GX50's have turned up and are merrily singing along to the Dust Brothers....
FrankHarveyHiFi said:I have to say, these have impressed me more 'straight out of the box'....I'm very tempted to try these for a movie based system, as they're very detailed, tight, and 'unboxy'.
FrankHarveyHiFi said:Lol, nooo! These are quite different from the RS and RX series - they're more like Platinum as far as their cabinet build quality is concerned, and for me, that gives better imaging and accuracy. These GX's seem far more balanced than anything that has gone before them.
MUSICRAFT said:I've got the GX100's playing (using a Hiato amp and QBD76 DAC) and they really are excellent speakers
plastic penguin - The Ribbon HF unit of the GX Series has no 'metallic edge' to it. Although the GX ribbon HF unit doesn't quite have the resolution, speed, subtlety or the overall accuracy of the Platinum Series Ribbon HF unit (the finest overall HF unit which i've heard to date btw) however the GX Series Ribbon HF unit does still project a highly focused, potent and detailed sound with excellent height, width and dispersion whilst remaining natural :bigsmile:
Btw, the GX Series has also got excellent levels of build, fit and finish 8)
All the best
Rick @ Musicraft
plastic penguin said:FrankHarveyHiFi said:Lol, nooo! These are quite different from the RS and RX series - they're more like Platinum as far as their cabinet build quality is concerned, and for me, that gives better imaging and accuracy. These GX's seem far more balanced than anything that has gone before them.
Saying they're like the PL range is like telling me about the great wall of China. I assume they don't have perceived 'metallic' edge to the treble, right?
FATS 2828 said:Hello, David . I know its early days, but do you think they might challenge the current best buy kings [500 to 1000] bracket
in the future ?
FrankHarveyHiFi said:plastic penguin said:FrankHarveyHiFi said:Lol, nooo! These are quite different from the RS and RX series - they're more like Platinum as far as their cabinet build quality is concerned, and for me, that gives better imaging and accuracy. These GX's seem far more balanced than anything that has gone before them.
I had a good listen this afternoon with the Fight Club soundtrack, which is a good tester in many ways, and can be very busy in parts, and come across as a mess or rather harsh in places if the system isn't up to scratch. The predominantly electronic soundtrack came across with excellent precision, with a clarity I would say is pretty rare at this price point. While metallic percussion instruments have a reassuringly metallic edge, these are definitely smoother than the RX and GS ranges. I find many good quality ribbon tweeter based loudspeakers are more able to distinguish between various different metal percussive instruments, particularly those whose frequency range reaches higher than normal. As far as bass is concerned, they're nicely balanced - no excessive bass, and no 'rogue' notes either - probably thanks to the cabinet's excellent build quality. The metal mid/bass driver seems to be very responsive, and take a bit more of a pounding than they look like they will. I think if you were to pitch the GX100's against your RS6's, you'd choose the GX100's. I think you'd be suitably impressed enough with the GX50's as far as the midrange and treble are concerned, but I think you'll need to look at the GX100's for sufficient bass, given you're used to the RS6's.
FATS 2828 said:Hello Rick, how are they on postioning ?
FATS 2828 said:Hello David, How would you describe the gx50,s sound compared too the atc11,s and proacs [ warm , sweet etc] .? Also their positioning flexability ?
plastic penguin said:MUSICRAFT said:I've got the GX100's playing (using a Hiato amp and QBD76 DAC) and they really are excellent speakers
All the best
Rick @ Musicraft
I've never said the RS6 have a metallic edge. Others have hinted to it, hence my term of "perceived", but not me. So how does the entry-level GX range compare to the RS6s? Bare in mind I'm talking about the Leema amp.
FATS 2828 said:Sorry Rick , yes gx 100 or 50,s .
MUSICRAFT said:plastic penguin said:MUSICRAFT said:I've got the GX100's playing (using a Hiato amp and QBD76 DAC) and they really are excellent speakers
All the best
Rick @ Musicraft
Hi plastic penguin
I know you weren't referring to the RS6's. I can assure that this did not even cross my mind.
Anyway the GX100's don't have the overall weight, scale, dynamics or the depth of the RS6's. Apart from this i would say the GX100's easily better the still impressive RS6's in pretty much every other area.
All the best
Rick @ Musicraft
