Monitor Audio BX2 Speaker Locartion
Coll
50
I have a pair of Monitor Audio BX2 speakers which are on top of room units and there is only a 10mm gap between the top of the speaker and the ceiling.
Because the speakers are well above ear level would it be best to use the speakers upside down.
If I do this the bass port will be very close to the ceiling will this then cause proplems. Room size is approx. 24sq metres. Ceiling height is 2 metres.
I have no other place to put the speakers so whatver speakers I purchase I would have the same problem.
I can't see you noticing a big difference turning them upside down. Is there no way they can be put on stands or even wall mounted brackets/speaker shelves as it's a shame to have them stuck in top of furniture so high up.
Coll
50
Thanks for comments, wish I could put them on stands but room layout and furniture placement prevent this so stuck with speakers high up on top of room units.
ASK THE COMMUNITY
