weesack:hi there i have just bought the ma bx2 and the ma centre speaker, i have tried to set them up using the yamahas set-up , using the microphone everything seems ok until i get a warning on screen saying that my f/l speaker is in reverse, i have never used one of these set-ups before can any one tell me what iam doing wrong, also i dont kow what to size the speakers in the yamaha set-up small or large, iam am a novice wuth this type of thing, any advice would be great, cheers
This can happen on the set up, if you are confident that the wring is correct (red to red etc) then ignore the warning, it is only an advice status and does not impact on performance
As regards small or large selection, try both and the variants of l/r and centre and see what is best for you (in terms of sound quality), the YPAO set up is really a comprehensive start up point...................but not the last word, that's up to you
Edit, hope this helps with the above commenst
