Hi
I am looking to downsize my current Marantz separates system for a Mini system. (wife feed up with large black slabs in the living room)
The problem is that I have been given conflicting advice as to what would be suitable.
I will be keeping my existing set of KEF 35.2 floorstanders so the system will need to be able to drive the speakers.
I am considering the following Mini systems:
DenonM37
Onkyo CR715
Onkyo CR725
The system is for my living room. Don't really need a system to deliver party volume levels but I don't want the system to sound weedy.
So far I have visited two branches of Ritcher Sounds and one branch of Sevenoaks HI-FI. Each visit has given me conflicting advice.
First visit to Richer Sounds, the salesman only had a M37 on display. He said that a mini system was not really suitable for my needs as they would all struggle to drive the speakers that I have, even the Arcam Mini Solo (which is out of my price range anyway) he advised that I go for a full size AV receiver (not really what I want) and forget the mini system idea as they all would sound rather lost.
On my visit to Sevenoaks HI-FI they didn't have any of the systems I was looking for in stock and I was told that any of the systems would drive the speakers but all mini systems are a compromise and the sound is not that great. I asked about the different qualities of the units I was looking at, the guy said that it doesn't really matter what system you buy as all minis sound nearly the same anyway? He did point me in the direction of the Arcam Solo Mini and said that would be OK but still a compromise. He then said that he had a Yamaha CRXM170 on special. When I asked to look at it, he said that it is a sealed box but it is as a good mini system as the others!!!. Not really the best salesman in the world.
I tried another branch of Richer Sounds they had the Denon and the Onkyo CR515 on display. The advice I was given was that any of the systems I was looking at would drive the speakers perfectly well. He did say that he had never heard the performance of the CR715/CR725 but did say that they are similar to the C515. He again pointed me to the Arcam Mini as he said it is of better quality than the others. He allowed me to try all the systems he had on display.
On listening to the Onkyo 515 connected up to a pair of budget Eltac speakers it sounded a little flat with a bit to much treble.
The Arcam was a big disappointment. It was connected up to a pair of £300 Arcam speakers and sounded terrible. No bass, over bright treble and not very clear at all. Not what I expect for £650.
I was really surprised by the Denon. It sounded really good. It was connected up to a pair or budget Gale speakers, but it had a clear, warm sound with a good bass/treble balance. I liked it the best out of all of the ones I tried. Unless I can try either of the other Onkyo's I might go with this.
But I am left with the following questions.
Will my speakers work with any Mini system .
How similar are the Onkyo's as I can't seem to find anyone local who has the CR715/CR725 on display.
I really like the Denon but will the Little unit be powerful enough for my living room.
Thanks in advance
DenonM37
Onkyo CR715
Onkyo CR725
Thanks in advance
