- Jun 23, 2008
- 20
- 0
- 0
Hi All you gurus out there.
Anyone heard of this cable? if so would it be any good for the HF duties in my system replacing my old Gale flat cheapy cable. If not, any recommendations for a good budget flat cable for HF. I'm using the Van dammme cable for LF which gives, IMO, plenty of weight and slam to my system. The reason for flat cable for HF is due to space in the conduit which I run my cables in. The Van Damme is very chunky and I don't have the room for two more runs of it.
Thanks All
Thanks All
