- Aug 10, 2019
- 2,556
- 5
- 0
First off, I know nothing about speakers or hifi systems so I need a bit of help.
I'm planning on purchasing the Marantz PM6004 after my Denon home theatre receiver broke. I still have the Denon SC-M51 speakers and I'm wondering whether these will work well with the Marantz and whether they're any good.
Here are the specs for the speakers (they're quite old):
Specifications for the DENON SC-M51 Speakers
Drivers 110mm woofer, 25mm soft dome tweeter
Type 2-Way Reflex
Impedance 6 Ohms
Frequency Response 75-20,000hz
Power Handling 75W MAX
Weight 3kg per Unit
Dimensions Width 165mm Height 215mm Depth 210mm
I don't even know if they are compatible? Should I get new speakers and which ones? (I'm on a budget so lower prices would be good)
Also will the Marantz unit work with the tv and Playstation 3?
Thank you for tolerating my complete lack of knowledge on this subject
Type 2-Way Reflex
Impedance 6 Ohms
Weight 3kg per Unit
