I am trying to put together a home theatre. The system is being set up in my library room which has a very high ceiling and is not closed on all sides as it has an open access to the staircase room. The size of the room is 20 ft (L) X 13 ft (W) X 15 ft (H). For avoiding glare from windows on the plasma screen, I am forced to use the width as the viewing direction/distance.
As a first step, I have bought Pioneer PDP 600M as the display. Now I am trying to system match receiver and speakers. Unfortunately, I am unable to find a single dealer where I am able to compare and match the various components that I had liked in different dealers. Hence, let me put down a list of components that I have liked in various auditions:
Speaker packages: Dali Ikon 6, Jamo C809, B&W 683s and CM7, MA Silver RX6
Receivers: Pioneer SC-LX 82 & LX 90, Denon 4310, 4810 & AVC-A1HDA
BDP: Sony or Pioneer BDP.
Have anybody been able to listen to various combinations to give opinions on matched systems? What are the views of What HI-FI editors/reviewers? Would you suggest that I look at something else other than those listed above.
Let us assume, within this range, price of any combination is OK.
Thanks in advance,
Thanks in advance,
