Match Advice
Razzler
31
Hi there, given the amp spec and speaker spec below, are these a good match
AMP
Analogue inputs
Input sensitivities
225mV, 20kOhm
Output level, tape
225mV, 100 Ohm
Power output (into 8 Ohms)
50W per channel
Overload margin, all inputs, all audio frequencies
35dB
Mains supply
115V, 230V
Dimensions (H x W x D)
70 x 432 x 301mm
Finish
Black
SPEAKERS
RMS power handling capacity 150 watts. Music power handling capacity 200 watts. Impedance 8 ohms. Frequency range 4+ -8 dB 40 - 20,000 Hz. Power at 96 dB SPL 2.5 watts. Sensitivity 1 W 92 dB. Distortion 250 - 1000 1000 Hz <0.5%. Cabinet principle: Bass reflex. Bass-woofer: 4 units 13 cm. Mid-range: 4 units 8 cm. Tweeter: 2.5 cm. Net volume: 32 litre. Excellent Looking, very impressive Looks and Sound.
I know, I am a very slow learner with this type info, I know you advised a couple of speakers but today I have been advised B&W 685 or Monitor BR5 but I still like the look of the B&O 6611.
Give what you know and the info below what do you advise. I need to make the best choice. I do play my music loud.
I don't know the B&O's but the ÿ685's beat the BR5's every time with the Naim.
If you live in a warehouse: no
If you live in a house with average size rooms: yes
