Marantz pm6004 vs cr603
I am currently trying to set up my new hi-fi setup, i want to use my laptop as the source, and have pretty much decided on the monitor audio bx2 speakers, although i need some advice on what component to use.
As far as I can see to use the pm6004 I need a DAC, whereas the cr603 is compatible. If so, is there going to be a huge diference between what these products can do, which is better etc. I hope the cr603 is good, because I can get a good deal on that here http://www.hifix.co.uk/hi-fi-package-deals/marantz/mcr603-black-inc-bronze-bx2.html
Also, because this is my first hi-fi setup, all my music is itunes downloaded is at 256kbps, i know cds run higher than this, is this going to make much difference. I dont want to spend a load on speakers and components and then not get there full potential because of poor quality music.
plastic penguin
1,675
121
19,870
Hi RdotJ
Can't comment on the 6004 but the 603 is a very capable little all-in-one. Really depends where your priorities lay? If you want a dedicated separates the the 6004 is the way to go, but for a 'plug 'n' play the 603 would be my choice out of the two.
However, there is the Onkyo TX-8050, although not heard, comes with shining recommendations on here.
Going back to the 603, Andrew Everard reviewed this amp and certainly worth a read: http://www.gramophone.co.uk/editorial/marantz-m-cr603-a-compact-solution-packed-with-performance
drummerman
540
The marantz micro is probably all most people would need. Plug in, forget and enjoy. A one stop solution and very neat.
regards
ASK THE COMMUNITY
