Marantz PM6004 + MISSION MX5 ?
ISAC69
73
hI
Recently I got a strong recomendations for the amp Marantz PM6004 this are his spec. :
Power Output (8 / 4 Ohm RMS) 45 W / 60 WPower Output (8 / 4 Ohm DIN) - / -Power Output (8 / 4 Ohm IHF) - / -Bridged Power Output (8 Ohm RMS) -Frequency Response 10 Hz - 70 kHzTotal Harmonic Distortion 0.07 %Damping Factor 100Input Sensitivity: MM 2.2 mV / 47 kOhmInput Sensitivity: MC -Signal to Noise Ratio: MM/MC 83 dB / -Input Sensitivity: High level 200 mV / 20 kOhmInput Sensitivity: Balanced High level -Signal to Noise Ratio: High level 102dB(2V
My question is if it can handle a large speakers as MISSIOM MX5 general spec. : Sensitivity (db/w/m) 90 / 8 ohm/ max power handling 200 w .
Or do I need the strongers and more expensive amp such as CA 840A or ROKSAN KANDY K2 ?
i have a limited budget so Your help will be higly appriciate !
:quest:
moon
47
The Marantz PM 6004 or the NAD 326 will both easily handle the MX 5's. No problem what so ever. Enjoy.
