Marantz PM6003 or Azur 540A?
Willferox
28
I picked up an Azur for real cheap and think I 'upgrade' (<--- assumption) to a PM6003 without losing money.
I listen to rock, metal, progessive mogwai stuff etc etc.
What do we think?
:cheers:
matthewpiano
494
330
19,270
It would be useful to know more about the rest of your system first. What source and speakers are you using? What do you like about the sound at present, and how do you want it to change?
Willferox
28
I have: Cambridge Audio S70 speakers & Cambridge Audio azur 540A amplifier connected via phono to an M-Audio Fast Track USB external sound card, which is connected via USB to my computer. I would say that my amplifier and speakers are sufficiently 'warn-in', and I am using high-quality cables. The 'sample rate and bit depth' properties for the driver, on my computer, are set to the highest settings - '2 channel, 24bit, 44100 Hz (Studio quality)'. For practical reasons, I play most of my music through Spotify Unlimited, which streams (having emailed Spotify for official reports) "99.9%" of their music "at [and not just 'up to'] 320kbps", mp3. I understand that these files are compressed and will be of a lower quality than CD's for example. My speakers are located about 3-4ft apart from each other, at a slight inward angle. I am sat just 1-2ft in front of my speakers, and my reciever is located directly in front of my, under my computer monitor. My room is small-to-average.
http://i41.tinypic.com/33w30h3.jpg
To put things into some context, I bought the Azur 540a with 340C for £120. They had been used only once and only with headphones.
moon
47
personaly I would centralize the amp on the desk and place some bookshelf or nearfield monitors either side of it . which are slightly tilted upwards and inwards towards your ears. this will give you an improvement of sound quality that no change in anplifier will ever match.
So there it is, I recommend a new pair of bookshelf speakers. how much budget do you have.?
Willferox
28
I bought standing speakers so that when I move out one day soon, I can have a nice rig infront of the TV. I might be able to get hold of an adjustable chair and move myself down a bit.
moon
47
ok, if you are happy thats all that matters! :)
