Marantz PM 6010OSE amp input dial problem
Hi. I've recently experienced problems with volume from the right channel. It usually starts with crackling from the right speaker with vastly reduced volume. When I switch the input control knob left then right it cures it, but then the next day it's back again. Any ideas?
What would you recommend as an upgrade if I go down that route - I play mostly classical stuff?
I'd say your amp is cheap enough to risk popping the top off and using a cotton bud covered in cleaning stuff and scrubbing right around the point of turning for that area of your amp and I'd say 5/10 times that fixes anything I've had that goes wrong lol. Give it a go you can't really break it just giving it a clean. Did it to the old Sony stereo amp running the speakers in my front room for the tv when the volume control was crackling/losing 1 channel and it's been good as new since
Sorry for the late reply. Yes, I agree that it would be worth having a look inside to see how easy cleaning the contacts would be. I'll have a go tomorrow and let you know if it works. Thanks.
