Marantz mcr603 with iPhone 4 makes crackles
Brand new mcr693. Monitor bx2. No Internet Til next week so Havnt done firmware update.
when playing iPhone 4 via USB cable get frequent high frequency ticks.
Anyone else have this problem?
Will it be cured by updating or should I send it back?
DAB sounds fine.
Ta
Max
603 obviously not 693
And no problem with original cd or same tracks
downloaded from same iTunes library to an iPod nano.
603 obviously not 693 And no problem with original cd or same tracks downloaded from same iTunes library to an iPod nano.
chebby
1,253
26
19,220
xeno said:
...no problem with original cd or same tracks downloaded from same iTunes library to an iPod nano.
Given that it works ok with the Nano then I would think the problem must be with the iPhone 4.
Once you have your internet connected (and the M-CR603 firmware updated via it's ethernet connection), make sure your iTunes software and then your iPhone software/firmware are all completely up-to-date and everything freshly sync'ed on the iPhone.
Depending on how long you have been without the internet, you may have missed a few updates on iTunes/iPhone/Nano.
I'd wait until everything is up-to-date then check again.
If (after all that) the problem persists, call Marantz (D&M) technical support on.... 02890 279835
